Close
You need to log in before you can reply       Login | Register now
[Help] Compile Samples with Keil uVision 5 - Lite ?
Author: copter 2017-7-27 16:06
0 376
Hey guys,for a university project i'll use the M100 + Onboard SDK to implement my own Code.
But: As it seems its not possible to compile / flash the OSDK-Examples using the free Version of Keil uVision as there is a limit of codesize of 32k.. The Sample Codes are above 100k.
Is there any chance to run the sample codes without getting the expensive pro version of uVision? Which (free)-Compiler do you recommend that can open / import the Sample-Projects?
I tried CooCox, AC6, EmBitz and Atollic Studio and none of them is able to Import the ".uvprojx" file that the sample-code comes in.
Any Ideas?
Thanks!
Reply
Replies
Quick Reply Back to top Back to list
