Close
You need to log in before you can reply       Login | Register now
[Device] How to receive gimbal camera images from other linux machine
Author: Taegoo Kim 2017-7-19 14:32
1 2567
Hi All,
I wonder if it is possible to receive gimabal camera images from other linux machine, in my case, Jetson TX2
To summarize my current project, I would like to attach Jetson TX2 on top of M100 to implement heavy computations like ML(Machine Learning) stuffs on TX2 using the camera images sent from the gimbal camera (currently, I am using Zenmuse X3 and Z3)
So far, I have found that since the CAM In and Out port information is secured by DJI and there is no image decoder, it is not possible to proceed my project other than receiving camera image data via ethernet port using DJI's manifold PC.
If anyone knows the way to solve this issue, please let me knwo.
Thanks,
Taegoo
Reply
Replies
DosBobs1
The Manifold is a customized Nvidia Jetson TK1, so you may be able to do your processing onboard.
2017-8-15 08:25
Quick Reply Back to top Back to list
