Close
You need to log in before you can reply       Login | Register now
[Help] OnboardSDK Battery Info
Author: sebastian.henin 2017-6-3 01:47
1 809
Hi
I recently purchased two DJI Matrice 600 aircraft and would like to use the  Onboard SDK to read battery information  during a flight.
My question is
Is it possible to read more than just battery capacity left with the Onboard SDK (I would like as much information as possible, Battery Voltage, Battery Current (A) , Battery Temp, Battery cell voltage etc)
If this is not  possible with the Onboard SDK, is it possible any other way?
Thank you,
Sebastian
Reply
Replies
c.jagielski
Sebastian, check out the code:  https://github.com/dji-sdk/Onboard-SDK/tree/3.2/osdk-wrapper
Hope this helps!
2017-6-10 06:01
Quick Reply Back to top Back to list
