Close
You need to log in before you can reply       Login | Register now
[Discussion] How to capture loss of remote signal
Author: newtonian 2017-3-21 04:31
3 527
I want to have the onboard sdk control the M100 when the remote control signal is lost.  In my tests the M100 just ignores my commands and performs a return to home (RTH).
Any suggestions?
Reply
Replies
Eduardo0
You can change the behavior of the finishAction like this:
initData.finishAction = finishAction;
// 0: no action, 1: return to home, 2 (default) : auto landing
// 3: return to point 0, 4: infinite mode (no exit)
If you are using the Linux wrapper you cannot use their function to initilize the WayPointData, I had to write my own to change these parameters.
2017-3-30 12:54
newtonian
Does this specify the action at the end of the waypoint(s) or when the RC signal is lost?
2017-3-30 23:29
Eduardo0
Only the action at the end of the waypoint(s), the RC Lost signal is WayPointInitData.RCLostAction.
2017-4-4 11:24
Quick Reply Back to top Back to list
