Close
You need to log in before you can reply       Login | Register now
[Manifold] autostart dji_sdk_read_cam
Author: yellow0720 2017-3-11 15:28
2 437
I am using ROS indigo and the DJI SDK. I can start dji_sdk_read_cam from on the manifold, but when i autostart these nodes with the manifold I cant start dji_sdk_read_cam (it starts but not the message below).
When manually start camera node on the manifold i get ---> TVMR: Video-conferencing detected !!!!!!!!!!!!!!!!!!
When autostart these nodes i get everything except this message. and all the information of image cannot be sent to another node.
Reply
Replies
yellow0720
does anybody know how to solve this issue?
2017-3-12 18:44
giuseppe.riggio
yellow0720 Posted at 2017-3-12 18:44
Hi,
I had a similar problem when I tried to start the node via ssh. In that case, the problem was that the camera drivers does not start via ssh.  I follow this:
https://developer.dji.com/onboar ... coding_package.html
and I solved my problem. Since yours is similar, maybe it will work for you too.
2017-5-2 22:34
Quick Reply Back to top Back to list
