Close
You need to log in before you can reply       Login | Register now
[Discussion] Usage of OSDK under STM32Cube
Author: neoTony 2017-2-18 09:09
0 286
Hello,
I want to run the OSDK under STM32Cube and Atollic as IDE.
Problem might be, that STM32Cube generated projects are not natively able to use C++,
so there is the ability to change settings according to C++.
But if I want to use the integrated FreeRTOS, which doesnt natively support C++, how I might do it better?
I do want to stay with the latest STM32 HAL Drivers and also I want to use a RTOS additional.
Is there a solutiion or some alternative way to do so? What is the prefered way to use Microcontrollers with the OSDK?
Best Regards
Antony
Reply
Replies
Quick Reply Back to top Back to list
