Close
You need to log in before you can reply       Login | Register now
[Discussion] error regarding "make" command
Author: Archit Kamath 2017-1-30 15:58
2 866
ubuntu@tegra-ubuntu:~/Guidance-SDK/examples/usb_example/DJI_guidance_example/build$ make
Linking CXX executable dji_guidance_usb
/home/ubuntu/Guidance-SDK/so/x64/libDJI_guidance.so: file not recognized: File format not recognized
collect2: error: ld returned 1 exit status
make[2]: *** [dji_guidance_usb] Error 1
make[1]: *** [CMakeFiles/dji_guidance_usb.dir/all] Error 2
make: *** [all] Error 2
When we run this "make" in manifold we are getting the above error. so please help us to overcome this
Can you let us know the bitsize of manifold?
This post contains more resources
You need to Login Before they can download or view, Not have an account?Register now
x
Reply
Replies
lorenzo_aldrigh
I had the same problem.
I use an ARM Processor (Beaglebone Green Wireless) and using Cmake it return the exact error.
I resolve editing the CMakeCache and CMakeFIle files changing the path of libDJI_gidance.so library.
Using the grep command you can find where the library is called, and you correct the path with your CPU architecture (x86 or x64 or ARM).
2017-2-23 00:18
Archit Kamath
lorenzo_aldrigh Posted at 2017-2-23 00:18
I use an ARM Processor (Beaglebone Green Wireless) and using Cmake it return ...
We solved it by reconnecting the guidance usb to the 3.0 hub on the manifold
2017-7-3 18:43
Quick Reply Back to top Back to list
