Close
You need to log in before you can reply       Login | Register now
[Help] Guidance obstacle distance problem
Author: Jesse CH 2016-12-30 15:39
1 4773
Hey guys,
I am using Guidance-ROS SDK. My application can properly acquire images and data from guidance , but there are some problems with obstacle distance information.
I did a test without any obstacle surroundedwithin 20 cm, and I got following result.
Obstacle distance: 20.000000 0.350000 0.250000 0.320000 0.580000
I also used a box to occlude camera1, and I got following result.
Obstacle distance: 20.000000 20.000000 0.260000 0.340000 0.490000
As you can see, the results are pretty strange.Does anyone have any idea about this?
Moreover, I had tried Guidance with official DJI GO (ios version). The CAN connection and DJI Guidance setting are correct, but I can not see any informantion about Guidance on DJI GO.
This post contains more resources
You need to Login Before they can download or view, Not have an account?Register now
x
Reply
Replies
MKZL
I have the same result as you just that my OD information shows a constant 80.0000 regardless of any object placed infront of any sensors. Even the ultrasonic information giving weird result as those numbers are in mm.
2018-1-26 12:02
Quick Reply Back to top Back to list
