Close
You need to log in before you can reply       Login | Register now
[Device] GPS specs
Author: almclare 2016-11-26 05:42
2 491
Hi,
I'm interested in hooking up a second device to the GPS unit that came with the M100. I can not seem to find any specs on the GPS unit, ie what the default baud rate is etc and what format the string type is in. I also thought there was a pin out for the GPS Can Port but I can not seem to find that either. Any help would be appreciated.
Reply
Replies
rabrown3@ksu.ed
I have the same problem.  I contacted DJI tech support about this issue and they said-  “Sorry, for commercial reason, we cannot provide the protocol of our GPS. And we suggest you use its original GPS module. Thank you for your kind understanding.”
So much for a “hackable” drone.
2017-1-6 23:03
ChrisJagielski
Do you really need information other than what the onboard SDK already provides? (Position, attitude... I'm sure it'll also give # of satellites)
- Chris
2017-5-14 00:16
Quick Reply Back to top Back to list
