Close
You need to log in before you can reply       Login | Register now
[Discussion] Image stream only works for downward facing camera
Author: robinabraham 2015-9-18 04:40
1 4548
When I run the USB example from the Guidance SDK, the image streams (with left and right camera views) only work for the downward facing camera/sensor. Depth images show up for the other sensors, but the camera streams are just noise.
Thanks
Robin
Reply
Replies
DJI-Sinsasion
Please check if the firmware of your Guidance is latest. Some very early products have this problem but we have fixed the issue long ago.
2015-9-24 16:51
Quick Reply Back to top Back to list
