Close
You need to log in before you can reply       Login | Register now
[Discussion] Obstacle distance is always 20
Author: robinabraham 2015-9-18 04:37
1 7971
When I run the USB example from the Guidance SDK, the obstacle distance shows up as 20 for all 5 sensors. The depth image is different, but the obstacle distance value is 20 across all of them.
Thanks
Robin
Reply
Replies
DJI-Sinsasion
This means the obstacle distance is invalid. Is it that you put Guidance on the ground and too near to some obstacle? You can try move Guidance 1+ meters away from obstacles and see if the numbers change.
2015-9-24 16:51
Quick Reply Back to top Back to list
